small coolant leak near
I have a question, well maybe two!
At the end of the Plastic air cleaner arm that connects to the Intake Manifold I have a small coolant leak on the underside of the IM where the plastic arm of the air intake box and the Im connect. looks like there is a small plate on the underside of the IM with a couple of screws, and in between looks like a gasket?
1. If it is a gasket, can I make my own gasket? What material or compound or both do you recommend?
thanks for any help you can toss my way.
GODSDOZER
GODSDOZER
bikingteacher
09-21-2009 09:50 PM
