Sponsored by: CARiD
small coolant leak near
Old Sep 4, 2009 | 11:53 PM
GODSDOZER's Avatar
Default small coolant leak near
I have a question, well maybe two!
At the end of the Plastic air cleaner arm that connects to the Intake Manifold I have a small coolant leak on the underside of the IM where the plastic arm of the air intake box and the Im connect. looks like there is a small plate on the underside of the IM with a couple of screws, and in between looks like a gasket?
1. If it is a gasket, can I make my own gasket? What material or compound or both do you recommend?
thanks for any help you can toss my way.
GODSDOZER
Old Sep 6, 2009 | 09:54 AM
GODSDOZER's Avatar
bump !
Old Sep 6, 2009 | 10:58 AM
Instead of asking a question, do a search, this is posted nearly weekly, very common and easy to fix.
Old Sep 6, 2009 | 11:44 AM
Disco C's Avatar
It is youre throttle body pre heater plate and gasket. common failure, $25 part.
Berryman
Oct 22, 2012 08:03 AM
ewok
Feb 13, 2011 09:41 PM
bikingteacher
Sep 21, 2009 09:50 PM
Rover Chris
Feb 26, 2009 11:07 AM
ccvalentino
Jan 6, 2008 08:11 AM
