Sounded Like a Motor Running Under the Rear Bumper
We are on a trip - towing our Disco II behind our motor home.
Once connected, I placed the 4x4 shifter into the Neutral position and Trans into Park - just like advised by other who also tow. I turned the key in the ignition to the SECOND position and heard a motor running under or around the rear bumper. It sounded like a power window motor noise. If I turn the key to the FIRST position, the noise goes away.
Any idea(s) what this noise was/is from???
Thanks
Thanks
Fuel pump makes a noise when running, and can be stopped by removing fuse 10 under hood. If truck has secondary air injection, I would suppose you might hear that pump motor out the exhaust, it blows air into the exhaust ports at cold start to burn off extra pollution. It has a relay in the underhood fuse box.
But should the fuel pump be running if the engine isn't? We are hearing the sound with the engine off and the ignition key is in the #2 position.
goatman
03-30-2020 08:54 PM
bcolins
12-09-2013 01:14 PM
bcolins
06-22-2013 08:55 PM
rezzrover
05-07-2013 06:02 PM
