Sponsored by: CARiD
Sounded Like a Motor Running Under the Rear Bumper
Old Aug 29, 2013 | 10:49 PM
Just For Fun's Avatar
Default Sounded Like a Motor Running Under the Rear Bumper
We are on a trip - towing our Disco II behind our motor home.
Once connected, I placed the 4x4 shifter into the Neutral position and Trans into Park - just like advised by other who also tow. I turned the key in the ignition to the SECOND position and heard a motor running under or around the rear bumper. It sounded like a power window motor noise. If I turn the key to the FIRST position, the noise goes away.
Any idea(s) what this noise was/is from???
Thanks
Old Aug 30, 2013 | 12:19 AM
Fuel pump makes a noise when running, and can be stopped by removing fuse 10 under hood. If truck has secondary air injection, I would suppose you might hear that pump motor out the exhaust, it blows air into the exhaust ports at cold start to burn off extra pollution. It has a relay in the underhood fuse box.
Old Aug 30, 2013 | 06:25 AM
drowssap's Avatar
Fuel pump x2
Old Aug 30, 2013 | 07:06 AM
Well, I thought fuel pump should cut off in like two or three seconds if it does not see 80 rpm or better from the crank position sensor. If fuel pump is not turning off, that is another issue.
Old Aug 30, 2013 | 08:50 PM
Interesting on the Fuel Pump.
But should the fuel pump be running if the engine isn't? We are hearing the sound with the engine off and the ignition key is in the #2 position.
Old Aug 30, 2013 | 09:09 PM
In your other post you state noise is from dash area....
You can pull fuse to isolate fuel pump. I understand that some of the gps generation may not be able to interpret the schematic diagrams, they do look like old Shell road maps....
goatman
Mar 30, 2020 08:54 PM
bcolins
Jun 22, 2013 08:55 PM
rezzrover
May 7, 2013 06:02 PM
tntbecca
Jan 18, 2013 12:22 PM
