Sponsored by: CARiD
Sounds of water under glove box....
Old Oct 2, 2012 | 07:48 AM
Rover7's Avatar
6th Gear
Default Sounds of water under glove box....
Hey everyone, I just got my 2001 LR disco 2 last week. I just needed a good work hauler and now I am finding I have invested more time at the garage than enjoying it on the road. When I hit the gas it sounds like water or something gurgling through the glove box area. I hear it has somthing to do with coolant but it this true? Should I be worried about driving it? Also, when the ck engine light came on, it started to act like it was going to stall out...one time it did. The garage tells me to drive it some more until it comes on again because it gave him 8 codes.
Thanks for any help.
New Rover Owner....
Old Oct 2, 2012 | 08:31 AM
Rovin4life's Avatar
You probably have a bad crankshaft position sensor. Seen that before causing multiple codes and stalling. Plus the water sound could be coolant or could be the ac drains as well. Are the carpets wet?
Old Oct 2, 2012 | 09:15 AM
drowssap's Avatar
"sounds like water or something gurgling through the glove box area" you have a coolant leak, at least it is low enough that you can hear air rushing through the heater core insteed of coolant.
You should stop driving the truck until you find your coolant leak. If you continue to drive it and it over heats it could quit possibly cost you an engine.
Also remember if there is no coolant them the gauge can not tell you it is overheating, the gauge must be submerssed in coolant to get a reading.
Old Oct 2, 2012 | 12:53 PM
Stop driving it.
Check and see if the wettness on the carpet is water or oily coolant.
How mechanical are you?
How much coolant are you going thru, only check the level before a cold start.
Old Oct 2, 2012 | 08:14 PM
Rover7's Avatar
6th Gear
I took my other car to work today and left rover home. Tonight, I checked the coolant and it was low. I bought some and filled it back up. Used about a 1/4 jug and mixed that with water. I started it up and went down the road and back (less than 1 minute drive) and still when I pushed the gas it was a rush of watery noise. The carpets are all dry...never have been wet. I parked it and put some cardboard underneath to see if I can see anything in the morning.
Old Oct 2, 2012 | 11:49 PM
Where are you in the Palmetto State?
Old Oct 3, 2012 | 06:49 AM
Rover7's Avatar
6th Gear
Default my rover is sick....
I am located in Spartanburg. (Upstate)
I am leaving it parked for today and checking the cardboard when it gets a little lighter outside....I'll report back.
Thanks everyone for all the posts!
Old Oct 3, 2012 | 06:37 PM
Rover7's Avatar
6th Gear
Unhappy Update
I got home from work and looked under the rover. Its dry. Carpet is dry.
So, CEL is still one, coolant is still looking topped off where I last left it.
Still hearing the big swoosh noise. Should I run it back into the shop and she what codes pop up now?
Old Oct 3, 2012 | 07:49 PM
blamo's Avatar
You have air in your system ! That is your noise
Old Oct 3, 2012 | 09:01 PM
The best thing you could do is perform a coolant pressure test which will show you any external leaks and if internal, head gasket leaks.
