Spongy Brake Pedal
Looking for ideas. I have replaced the master cylinder, brake booster, the two rear calipers and bleed the entire system yet I still have a very spongy pedal. The car stops fine when you push hard, but there is not sense of an ability to slow down gradually. I have had the rover for 8 years so there is no way this is expected function with the above mentioned new parts. I am looking for any additional troubleshooting ideas. Thanks
I realize this is an older thread (I'm reading as much as I can, I just got a 1996 Disco), but I wanted to throw another possibility? I had a 1992 F150 that acted the same as described with the brakes. It turned out to be a faulty ABS valve. I just remove it from the system. I drove many vehicles without ABS.
