Sponsored by: CARiD
Spongy Brake Pedal
Old Jul 14, 2013 | 06:16 PM
96discofanorvictim's Avatar
Default Spongy Brake Pedal
Looking for ideas. I have replaced the master cylinder, brake booster, the two rear calipers and bleed the entire system yet I still have a very spongy pedal. The car stops fine when you push hard, but there is not sense of an ability to slow down gradually. I have had the rover for 8 years so there is no way this is expected function with the above mentioned new parts. I am looking for any additional troubleshooting ideas. Thanks
Old Jul 14, 2013 | 07:36 PM
Flexible line that connects brake system to wheel mounted components - is it swelling when pressure arrives? Flushed all the fluid with new DOT4 and re-bleed? (contamination or water)
Old Nov 10, 2013 | 10:44 PM
Sinner's Avatar
I realize this is an older thread (I'm reading as much as I can, I just got a 1996 Disco), but I wanted to throw another possibility? I had a 1992 F150 that acted the same as described with the brakes. It turned out to be a faulty ABS valve. I just remove it from the system. I drove many vehicles without ABS.
Old Nov 10, 2013 | 10:54 PM
dusty1's Avatar
Dolomite!!!!
Old Nov 11, 2013 | 06:18 PM
OffroadFrance's Avatar
Did you follow the textbook bleeding process from the RAVE manual?. Brake bleeding is very specific and many have had difficulties after replacing major brake parts. Also as Savannah states, the flexi hoses next to the wheels perish and balloon under pressure giving a soft spongy pedal.
norwood16
Apr 7, 2015 09:25 AM
Petunia
LR4
Nov 5, 2011 11:30 AM
iownme
Nov 16, 2009 09:51 AM
tommytwotone
Sep 28, 2009 09:04 AM
pc jamie
May 27, 2008 07:31 PM
