Sponsored by: CARiD
Squeaking noise on my 2003 Discovery
Old Feb 11, 2020 | 05:09 PM
jwthompson76's Avatar
4th Gear
Default Squeaking noise on my 2003 Discovery
I recently purchased a 2003 Discovery 2 (which I love btw). When I accelerate its making a squeaking noise and when I let off the gas it quits. Sounds like it’s coming from underneath. Could this be attributed to one of my U joints? Can anyone help? Thank you!
Old Feb 19, 2020 | 05:40 PM
Boostle's Avatar
Yes, this is a tell tale sign that the U-Joint is going to fail soon. At first its a squeak. Then it sounds like birds chirping. Then it breaks. Replace it asap.
Old Feb 19, 2020 | 08:05 PM
mollusc's Avatar
You're lucky that it's giving you this warning sign. Many times there's no notice at all before the front driveshaft detonates and takes out the transmission or the lower case of the engine.
As mentioned, replace the driveshaft immediately. I would not drive it until you do.
DenverDiscoII
Feb 12, 2020 08:57 PM
Carguy
May 24, 2012 03:33 PM
Rovermike85
May 7, 2011 06:49 PM
mara9205
Oct 22, 2010 04:48 PM
richief556
Oct 22, 2010 09:16 AM
