Sponsored by: CARiD
Stalling and kicking at speed
Old Dec 22, 2016 | 09:58 PM
RaudyRover2001's Avatar
Default Stalling and kicking at speed
So out of nowhere a few weeks ago I was in somewhat slow traffic and I experienced a huge kick in the engine followed by another. Since then the kicks and momentary drops in power have continued on and even started stalling at the idle. I have a good collection of codes but don't know what to go after. I also cleaned my throttle body and took the idle control valve off and gave it a shot of carb cleaner as well as a light shaking. Codes are as follows:
P1884
P1590
P0441
P0455
P0133
P0430
P0153
P01412
P01415
P0102
P1174
im living with a very low budget so I really just want to know the most likely culprit since these codes seem to come from all over the truck
HELP!!!
Old Dec 25, 2016 | 08:26 AM
chubbs878's Avatar
Doesn't point to anything with misfires which usually starts this symptom that you experienced. I may be off, but checking your charging system thoroughly is a good start. Battery post clamps and corrosion; tight and clean. Get the alternator tested, it's easy to remove. Just a lot of random codes that aren't closely related. Could be that ECU is not getting enough power
Old Jan 9, 2017 | 06:59 AM
Shadow993's Avatar
Clean mafs with proper fluid
kfx4001442
Jun 11, 2013 11:45 AM
benisraeli
Apr 14, 2012 01:15 PM
hsipromo
Jan 17, 2010 09:19 PM
pauper
Sep 21, 2009 11:50 AM
TexasLR3
Sep 24, 2007 12:03 PM
