Start problem
The key will not turn, and I hear three clicks in the steering column. What to do?
I have tried to disconnect the battery and tried to pull fuse number 18 with no luck.
Must I drill a hole in the steering column and lubricate the solenoid?
The connection between the key and the car is also gone. Cannit open or lock with the remote control
2003 model. Took down panel under steering wheel and pulled the connector. Put it back and still same three clicks and no start. I must buy a used column maybe?
bhorwhat
Oct 29, 2008 12:55 AM
