Sponsored by: CARiD
Starting help
Old Jan 3, 2008 | 11:20 AM
medic67's Avatar
4th Gear
Default Starting help
I have a 1994 Discovery, manual shift. It starts all the time except now that it is very cold. 0*F to 20*F. I went to leave work yesterday morning and it wouldnt start. I would turn the key and all I got was a noise from under the dash on the passengers side. So I left it till later in the day and after it had set in the sun it started right up first try. Now this morning it did the same thing. I am searching for an answer!
Thanks for the help in advance.
Larry
Old Jan 3, 2008 | 11:40 AM
Default RE: Starting help
Start with cleaning and reconnecting the battery cables, if that doesn't work, get it jump started and go down to Auto Zone or any local parts store and have them run a free battery/alternator test.
Old Jan 3, 2008 | 01:02 PM
medic67's Avatar
4th Gear
It wont take a jump start. I cleaned the posts and cables already. Thanks
Old Jan 3, 2008 | 02:02 PM
Then pull the battery and take it down to be tested.
Old Mar 14, 2010 | 12:19 AM
medic67's Avatar
4th Gear
Was actually water in a relay under the dash that had frozen. Once it thawed it started. Fixed leak around windshield so it wouldn't happen again.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
alpinab7
Nov 5, 2006 12:36 PM
martini7
Sep 22, 2006 08:18 PM
readdiscovery
Jul 7, 2006 05:23 PM
asmcmillin
Apr 10, 2005 12:16 AM
