Sponsored by: CARiD
Steamy Vents
Old Jun 5, 2009 | 03:25 PM
michar911's Avatar
3rd Gear
Default Steamy Vents
My 1999 Discovery II has steam coming out of the heater vents. I am assuming it's a failed the heater core. Can anyone give me a rough etimate of the repair cost?
Old Jun 6, 2009 | 02:44 AM
tedly797's Avatar
Hi,
Heater core replacement is roughly $400 to $600 labor depending on where you go. I couldn't tell you the cost of the part it's self.
Let me ask you, Does the steam smell sweet/bitter? Is it coolant or water your seeing? The reason I ask is because the a/c drains will block up with dust and cause your evaporator to drip water inside the car and vents. you'll notice the floor boards might be damp on either side of the heater unit. At first start up, the hvac will fog everything up until the a/c or heater is able to dry the air a little bit. Check your a/c drain tubes! Located under the car about where the heater is located on either side of the transmission. take a long screw driver or coat hanger and poke inside the drains. Be carefull of the cats as they will be hot if the car has been run. Also, water WILL run down your sleeve if you do unplug a blocked drain.
Effie1959
May 28, 2013 06:18 PM
Eak69
Apr 4, 2010 11:52 AM
4x4freak
Apr 11, 2007 09:48 PM
marco
Nov 19, 2006 07:03 AM
PAXPAY
Aug 16, 2006 12:26 AM
