Sponsored by: CARiD
Stiff key tumbler on Disco 1
Old Oct 6, 2007 | 07:34 AM
Catsailor's Avatar
3rd Gear
Default Stiff key tumbler on Disco 1
Bought a Disco 1 cheap and one problem is the keywon't turn sometimes- just seems that the tumblers don't retract all the way. You have to carefully turn and turn until it finally goes, then the truck starts right up. Any advice? I don't really want to replace it because then I have two seperate keys for doors and ignition - but if I have to I'll replace it. Also tried a locksmith cut key but does not help. Would a new key from LR help? I am doubtful.
Old Oct 6, 2007 | 07:45 AM
Default RE: Stiff key tumbler on Disco 1
Go by a lock smith and have then clean and or lube the tumblers, alot of times old metal shavings from the keys, as they wear down, get stuck in the tumblers.
Old Oct 6, 2007 | 07:05 PM
fire1427's Avatar
I had a similar trouble with another vehicletried the locksmith the key he cut was from my worn original ... I took my vin# had a dealer cut new one and no troubles ... dunno if rover can do it ....
Old Oct 9, 2007 | 05:16 AM
rumpig70's Avatar
hey i had the same problem with my93 disco, a couple of squirts with inox fixed it in a matter of seconds.
TOM R
Aug 14, 2015 09:58 AM
JoMar
Jun 26, 2013 06:20 PM
squid
Freelander
Mar 13, 2009 06:45 AM
viper205
Jun 23, 2008 08:14 AM
dillhole
May 31, 2008 06:40 AM
