Sponsored by: CARiD
Stuck in low gear
Old Aug 22, 2017 | 06:17 PM
Hdupree's Avatar
Default Stuck in low gear
Help! LR3 06 stuck in low gear with the following faults after washed under carriage and cleaned under the hood and changed head lights, codes tramission fault, HDC, Parking brake, and the low range gear flashing I can only drive in low gear. Help I've changed the battery a month ago.
Old Aug 27, 2017 | 07:06 PM
abran's Avatar
Transfer case ECU or TCCM as it's called behind battery. It gut wet and now has corrosion on it.
remove and try to clean, if not get a new one.
Old Apr 1, 2020 | 11:50 AM
Begul2020's Avatar
3rd Gear
Default Same problem.
Hi Sr. You solve this problem ? Please let me know because I’m in the nightmare with my Lr3. Thanks.
Lmmdop
Aug 11, 2020 12:02 PM
Jay Jex
Apr 9, 2018 02:11 PM
Lion Heart
Mar 16, 2012 03:52 PM
Kevinmward
Nov 5, 2010 09:12 AM
bearcatfans
Dec 11, 2007 08:55 PM
