Sponsored by: CARiD
Subwoofer wiring
Old 12-28-2021 | 11:03 AM
Discotom's Avatar
Default Subwoofer wiring
Hi, I’m a new owner of a 1998 discovery. Can anyone help with this? The subwoofer assembly was removed from the tail gate. I’m left with this connection and I’d like to connect speakers.
Old 12-28-2021 | 03:45 PM
WaltNYC's Avatar
First, welcome to the club! You'll get better results posting in the D1 section of the forum.
This should help. The last post is the money shot.
https://landroverforums.com/forum/di...89/#post267578
You will need an amplifier. The stock, 15W amp was attached to the back of the speakers. I bought a 250W mono amp and put it in the pocket next to the speakers.
I recommend these drivers...
Amazon Amazon
Old 12-29-2021 | 08:52 AM
Discotom's Avatar
Thanks for the input, noted about D1 thread.
Luckily I’ve held on to an old mono amplifier that I bought almost 20 years ago.
this may be a question for an audiophile. But how would I go about connecting the inputs from the tailgate to the amp?
Old 12-29-2021 | 06:51 PM
WaltNYC's Avatar
Usually you can wire up just one RCA connector. Pin 2 (red wire) is audio +. Pin 3 (black wire) is audio -. Look for very small PIN numbers on the connector. Depending on the amp you may need to split them (make a Y) and wire both RCA connectors.
elboy0712
07-03-2021 08:48 PM
MrHSE7
09-25-2020 04:57 AM
bmwrovers
01-13-2020 02:09 PM
Asher Levine
02-07-2019 07:06 PM
MRDM1
Audio/Visual Electronics
05-13-2008 04:24 PM
