Sponsored by: CARiD
Subwoofer wiring
Old Dec 28, 2021 | 10:03 AM
Discotom's Avatar
Default Subwoofer wiring
Hi, I’m a new owner of a 1998 discovery. Can anyone help with this? The subwoofer assembly was removed from the tail gate. I’m left with this connection and I’d like to connect speakers.
Old Dec 28, 2021 | 02:45 PM
WaltNYC's Avatar
First, welcome to the club! You'll get better results posting in the D1 section of the forum.
This should help. The last post is the money shot.
https://landroverforums.com/forum/di...89/#post267578
You will need an amplifier. The stock, 15W amp was attached to the back of the speakers. I bought a 250W mono amp and put it in the pocket next to the speakers.
I recommend these drivers...
Amazon Amazon
Old Dec 29, 2021 | 07:52 AM
Discotom's Avatar
Thanks for the input, noted about D1 thread.
Luckily I’ve held on to an old mono amplifier that I bought almost 20 years ago.
this may be a question for an audiophile. But how would I go about connecting the inputs from the tailgate to the amp?
Old Dec 29, 2021 | 05:51 PM
WaltNYC's Avatar
Usually you can wire up just one RCA connector. Pin 2 (red wire) is audio +. Pin 3 (black wire) is audio -. Look for very small PIN numbers on the connector. Depending on the amp you may need to split them (make a Y) and wire both RCA connectors.
elboy0712
Jul 3, 2021 07:48 PM
MrHSE7
Sep 25, 2020 03:57 AM
bmwrovers
Jan 13, 2020 01:09 PM
Asher Levine
Feb 7, 2019 06:06 PM
MRDM1
Audio/Visual Electronics
May 13, 2008 03:24 PM
