Sponsored by: CARiD
Sunroof problems
Old May 13, 2006 | 12:16 AM
luluespy's Avatar
3rd Gear
Default Sunroof problems
Recent proud owner of a 2003 Land Rover Discovery II.
My rear sunroof will not open. I have checked the fuses with no luck. I do not have an owner's manual. When you push the rear sunroof button, there is no motor running. Is there another fuse, besides the one under the steering wheel for the sunroof?
Hoping it's something simple I can fix without taking to shop.
Old May 13, 2006 | 12:48 PM
Default RE: Sunroof problems
It will take a little testing, do you have power to the rear roof? I believe you have a relay and I also believe the sun roofs are controled thru a ECU. Of course it could be a locked up motor.
Wish I could be more help.
Mike
Old May 17, 2006 | 08:29 PM
luluespy's Avatar
3rd Gear
I have checked the sunroof again and it does not seem to have have any power, or at least I can not hear the motor coming on at all. I was reading on another reply and it said the sunroof motors were behind the glovebox, is that true. I do not want to start taking the Rover apart until I know what I am looking for.
Also, I am sorry but I am not too educated on the car talk, the ECU, are you meaning the Electric Control Unit? Where would that be?
Thanks for all your help.
Old May 17, 2006 | 10:27 PM
The motors are not behind the glove box, they are located at the sun roofs.
If you are unable to verify power to the motor with a probe I would suggest you get it to a shop that is justed to repairing them. You are looking at either a fuse, a relay, a switch, a bad motor or an BECU that is causing the problem.
Mike
Frank4
Mar 21, 2014 05:21 AM
Seandalt
Feb 18, 2014 06:31 PM
fire771087
Mar 9, 2012 10:46 AM
BigRed98
Jun 21, 2010 12:30 AM
Disco-Nate
Sep 28, 2009 09:06 AM
