Sponsored by: CARiD
97 RR, radio wont work, HELP!!
Old Feb 13, 2006 | 05:00 PM
aliciacassarino's Avatar
3rd Gear
Default 97 RR, radio wont work, HELP!!
this morning, i had the radio on, and when i pulled out of my driveway, as soon as my front tires got off of the curbing between the driveway and the street, the radio stopped working!! help! please! the cd player works fine, so does the tape player. does anyone know what i should do?? is it a loose wire, a fuse? helllllllllllp!
i have a 7 week old baby that will only calm down in the car listening to a certain classical station, so i REALLY need some advice. there may even be a reward in it, i am THAT desperate.
Old Feb 13, 2006 | 10:56 PM
Bait's Avatar
Default RE: 97 RR, radio wont work, HELP!!
ORIGINAL: aliciacassarino
Is there any sound from the radio ? Static or just silence
Old Feb 13, 2006 | 11:43 PM
mikemeyer0's Avatar
yits not in WX mode is it, if you have that?
Old Feb 14, 2006 | 01:36 AM
3rd Gear
just silence and a popping when i adjust the sound way up.
Old Feb 14, 2006 | 01:37 AM
3rd Gear
i dont think so, but then again, i dont know what that is.
Old May 17, 2006 | 08:19 PM
CronicJoeBlunt's Avatar
The antenna leads may have came loose from the back of the radio or the problem may be internal, also make sure you did not accidentaly switch it to the weather band mode
Old May 17, 2006 | 10:35 PM
Having had 4 children I know what you mean about drive them around to put them to sleep listening to music, sounds like you are in deep DU DU.
If your CD player and tape player are working you have an internal problem, like a bad ciruit board.
See if you have a auto radio shop anywhere near and talk with them.
Mike
Ridgeline Adventures
Dec 23, 2021 12:18 PM
armyeng
Mar 8, 2011 05:58 PM
bhorwhat
Oct 16, 2007 10:14 AM
dmm698
Aug 28, 2007 06:37 AM
