Sponsored by: CARiD
Tail Gate
Old Aug 31, 2007 | 07:29 PM
jadams5332's Avatar
Default Tail Gate
I have a 2005 LR3. Today the tailgate failed to open when the rest of the car was unlocked. The gate "clicks" when the locks are released, but the actual operation of lifting the tailgate does not work. My assumption is the release is jammed/disconnected rather than it being a lock problem.
Any ideas how to get around this? Is there a manual method of opening (similar to the lever/pull inside the trunk of most cars)?
Old Aug 31, 2007 | 07:55 PM
Default RE: Tail Gate
If you are still in warranty, I would get it into a shop, that lock actuator is a little expensive and better delt with by the dealer.
If you are not in warranty, not being familiar with the inside lock buttons, if you have one, I would crawl into the cargo area and unlock it by hand until you can get it replaced.
Old Sep 1, 2007 | 01:05 PM
jadams5332's Avatar
Have booked it into the dealer (told there was a two week wait, but got it down to Wednesday). Have searched for emergency manual unlocking from inside, but interestingly appears there is none. Not sure how the dealer will open it to fix the problem. Thanks for the reply.
Old Sep 1, 2007 | 03:56 PM
With the ultimate Rover, a BIG hammer.
Old Oct 22, 2008 | 07:41 PM
Techspert's Avatar
I have the same tailgate stuck issue. I can hear the usual noise when I press the tailgate release button but it will not open.
Does anyone know how to get it open from the inside? How does one know how to get inside the plastic pieces from the inside?
The dealer told me it would be at least $300 to fix it.
Old Oct 23, 2008 | 11:17 AM
D2's Avatar
D2
I had this same issue where I could here some movement but it would not unlock/open On my 99 D2. if youremove the rear speakerunityou can access the lock/open mechanism ( sorry don't know the official name). In my case a small platic connector that connects the rod to the mechanism had brooken I found onesimilar at auto zone. It has been a while but I think a small wrap of tape was added for extra security. hope this helps
Old Dec 6, 2008 | 04:21 PM
WozniakMac's Avatar
Where is the lock in the cargo area? I have been back there, but I am not sure what to look. Thank you.
lipadj46
Aug 22, 2009 08:04 PM
samwise90
Apr 27, 2008 04:58 PM
mrmckay
Mar 28, 2007 02:15 AM
Hutchings
Jan 30, 2007 01:39 PM
kfordric
Aug 24, 2006 03:52 AM
