Sponsored by: CARiD
Tailgate Window
Old Sep 9, 2008 | 09:48 AM
cabbie22's Avatar
3rd Gear
Default Tailgate Window
Can anybody please help with this Freelander[/b] problem? Approximately 3 weeks ago the tailgate window started working backwards when you pushed the up switch the window went down and visa versa also the rear window wiper stopped working. We were told that it needed recalibration and removed the battery, now the window no longer works at all up or down from the switches, key or the fob and the glass is stuck on the outside of the vehicle. When the switch is pressed up or down there are four (4) beeps and nothing happens. If you hold your hand on the relays above the rear arch they can be felt clicking on and off, if you hold your hand on the window motor inside the tailgate a click can also be felt. Any ideas on how this can be rectified or resolved would be very much appreciated.[X(]
Old Sep 9, 2008 | 07:04 PM
roverguy7's Avatar
Default RE: Tailgate Window
if you disconnect the batt and let it sit for about 5 minutes, and then hook it back up, when you turn the key back on the glass should go back down, soundslike you already did that though
Old Sep 10, 2008 | 07:15 AM
cabbie22's Avatar
3rd Gear
Thanks for your prompt reply! but no luck on that battery removal The window still not moving looks like i will have to go to landrover dealer for dignos.
Old Sep 10, 2008 | 08:24 PM
roverguy7's Avatar
try latching the door latch, use a pen or something and then do it
Old Sep 11, 2008 | 04:59 AM
cabbie22's Avatar
3rd Gear
Thanks again roverguy7 but Still no luck ?
FreeTrouble
Freelander
Mar 5, 2014 12:54 PM
TD4 2000
Freelander
Jan 21, 2011 03:41 AM
trophy900
Freelander
Jan 20, 2011 11:04 AM
quant5m
Sep 25, 2010 11:31 AM
Red8
Freelander
Jul 16, 2009 01:04 PM
