Sponsored by: CARiD
TC light on DISCO 2
Old Mar 27, 2012 | 09:33 PM
jayg's Avatar
Default TC light on DISCO 2
I've been slowly fixing up my discovery, got the ACE system working again, since I've bought it the TC light has been on, I've drove it to a steep hill and seems like only tires in front were spinning, is there an obvious cause, no other lights are on but the TC light. Any tips to try would be great
Old Mar 27, 2012 | 09:56 PM
With the traction control light on the traction control will not work, nor will the ABS in most cases.
Many things can cause this, these are some of the hardest issues to diagnosis.
If the TC worked your wheels would not spin.
Old Mar 27, 2012 | 10:27 PM
jayg's Avatar
Where should I start, I have the rave manual but I can't seem to find any troubleshooting steps, I'm thing fuses and relays, the ABS seems to work fine
Old Mar 28, 2012 | 04:55 AM
In the Brake section.
Here a some of the pages. Note that one thing that can keep light on is center diff lock on. You'll want to be sure all lamps come on at power up self test, because combination of lamps displayed later is important. Some previous owners "disco"nnected or painted over lamps.
File Type: pdf
File Type: pdf
Old Mar 28, 2012 | 07:19 AM
jayg's Avatar
Seems like I might have a bad passenger side wheel bearing, could this cause the TC light to come on? when I start the vehicule all lights pop up so i know they have not been disabled or painted!! Thanks guys, Is the 4 x 4 still operationnal without the TC working?
Old Mar 28, 2012 | 07:41 AM
There is no on/off for the 4WD
Old Mar 28, 2012 | 08:25 AM
You need to get your codes read by a mechanic that has a test book or other scanner that has Rover software. How do you know you have a wheel bearing/hub failing?
Old Mar 28, 2012 | 02:29 PM
jayg's Avatar
Its stared to have a humming noise from the front passenger side, from my experience with other vehicule this is my thoughts, its my first discovery so I could be wrong, I tried hammering the brakes a few times today but ABS is not working, the light works when I start vehicule but in fact it doesnt work. Brakes and rotors are new.
Old Mar 28, 2012 | 09:13 PM
You have a bad hub assembly.
Replace it, have the codes cleared.
Old Mar 29, 2012 | 07:06 PM
jayg's Avatar
what do you think of a used hub assembly? there are a few discovery 2s at the wreckers and was thinking i could maybe get one there and save money, the install doesnt look too bad! thanks again for all the info guys, its great you help us rookies out!
