Sponsored by: CARiD
TD5 coolant pressure
Old Sep 14, 2006 | 03:22 PM
m0dwk's Avatar
3rd Gear
Default TD5 coolant pressure
Hi,
Can anyone tell me what the pressure in a TD5 cooling system should be? It seems on my 1999 90 that the hoses are still hard even 3 hours after having driven for 45mins on the M6. The coolant level is at the bottom of the filler jar, but returns to normal if I let the pressure out slowly via the filler cap. Is this normal? I am losing a little coolant through the pipe joint at the thermostat.
Thanks,
Chris
Old Sep 15, 2006 | 11:15 AM
Default RE: TD5 coolant pressure
I am guessing your pressure should be at about 15#s , same as a gas engine.
Where does your coolant level sit when cold? I would suggest you raise it so that when the engine is hot your level is an inch or tow from the bottom of the bottle.
As for the hoses staying hard, sounds normal for your hose to hold pressure longer, it is a diesel and a big block to cool. Should get that coolant leak fix sooner then later.
Mike
Old Sep 16, 2006 | 05:57 AM
m0dwk's Avatar
3rd Gear
Thanks Mike,
It was more a question of whether the head gasket might be leaking and allowing gas (air or exhaust) to pressurise the cooling system. Having said that, no water in the oil, no oil in the water etc etc. I do have a slightly odd trait - when I'm at 70mph and I accelerate hard to overtake, the engine sometimes faulters. I was wondering if the two were connected.
Chris
Old Sep 16, 2006 | 12:51 PM
I don't believe the two have anything to do with one another. I would suggest you have a shop do a pressure test on your coolant system, make sure it is not running to high.
As for the hesitation, cna't help you there.
Mike
Old Sep 16, 2006 | 03:35 PM
m0dwk's Avatar
3rd Gear
Thanks for that! Taking it in on Wednesday to have the engine looked at.
Chris
pgaukroger
Feb 29, 2016 05:56 AM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
suveer
May 9, 2007 08:20 AM
trini defender
Defender
Dec 11, 2006 05:14 AM
