Sponsored by: CARiD
Thermometer check for disc brake problems
Old Feb 16, 2011 | 11:00 AM
Default Thermometer check for disc brake problems
I used a cheap infrared non-contact thermometer to "zap" the temperature readings of my brake discs. Left front was 40 degrees warmer than the others after a short drive. I had suspected a warped rotor (death wobble when braking at 55).
Sure enough, found partial stuck caliper piston on inboard side, brake pad thin on that side from too much wear, and replaced the warped rotor.
I would guess that if a rotor is making more contact than it should, it would be warmer than one on the other side of the car. All that friction has to go somewhere.
euronavdiscs
Feb 6, 2016 03:41 PM
OffroadFrance
Jul 28, 2015 01:52 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
filbs
Jun 12, 2012 03:43 PM
sforb
May 18, 2009 10:46 PM
