Sponsored by: CARiD
Throttle actuator won’t open
Old Jan 21, 2024 | 03:06 PM
WillyDisco's Avatar
Default 04 Disco II Throttle lever won’t open
Hi forum! I did a quick search here and YouTube but I can’t find anything about the throttle body getting stuck in the closed position. I am putting the throttle cables back on after doing the valve covers but I can’t open the throttle plate wide open to feed the cables back onto the throttle lever. There is a back plate that they hit and I cant seem to move it/get it out of the way.
am I missing something obvious? Is it a security feature? The throttle body was loose and being moved around lots while I fought with intake plenum and valve covers.
anyone experience this?
thanks in advance folks
Bonk
Old Jan 22, 2024 | 08:33 AM
mollusc's Avatar
You probably should say what Rover you're talking about, and then post in the subforum for that vehicle.
Old Jan 22, 2024 | 07:20 PM
Best4x4's Avatar
Looks like a D2, and you should be able to grab the part the cables sit in and rotate it in order to get the cables for throttle and cruise control back in their slots.
Old Jan 22, 2024 | 10:20 PM
WillyDisco's Avatar
Thanks Best4x4
The part won’t rotate more than 2 or 3mm. On tear down I was able to rotate the housing the cables sit in all the way wide open to remove the cables but the part bumps into a stopping plate.
WildPackofFamilyDogs
May 30, 2023 09:08 PM
LR2driver
LR2
Jan 26, 2022 11:27 PM
Externet
Jan 4, 2018 01:00 AM
Broken08
Jun 28, 2015 03:29 PM
Prepilot_3ck
Feb 13, 2012 09:36 AM
