Tire Size
Old 04-16-2012 | 07:40 PM
jayg's Avatar
Default Lift Kit and tires
Hey guys, after reading a bunch of older post on lift kits I'm a little confused, I'd like to add bigger tires and gain a little clearance, I use my 2000 Discovery for a little off-roading and to pull my 21 foot boat (4200 pounds, dual axle trailer)
I really like the look once lifted, I have an ARB bumber installed already, I'd rather not do any mods minus the actual suspension, wondering where I can call to purchase a kit, all the post are years old and maybe something better has come out.
I have air suspension in the back, wondering as well if I can still use the ACE system once I remove the standard air shocks or should I leave it disabled? I had a leak in the back line and was gonna replace it while doing the lift
last question is what tires sizes should I be looking for, I have 18 inch rims an would like to keep them, thanks for the help!
Old 04-17-2012 | 06:18 PM
Chris-bob's Avatar
Have you done a search in the D2 section?
Old 04-17-2012 | 06:41 PM
fishEH's Avatar
Call Justin @Lucky8
Lucky8 LLC
Old 04-17-2012 | 06:58 PM
jayg's Avatar
thanks guys, I did have a look, post that had good info were 4 years so I opted to post here and get current up to date info as things change over the years!
jigray3
10-14-2010 06:54 PM
jigray3
10-09-2010 09:27 AM
samsly
Tires
02-27-2006 07:01 AM
chefman
01-18-2006 10:15 AM
jhstew1
06-14-2005 03:41 PM
Quick Reply: Tire Size
