Sponsored by: CARiD
Traction Control Problems
Old Apr 2, 2013 | 07:10 PM
Originally Posted by jafir
This is bad information. It may be true with a NEW cluster (not sure... never considered using one) but it is certainly not how a used cluster works. If you put a cluster in with different miles than the BCU has stored, the cluster will still display the miles IT has recorded and will blink because it doesn't match what the BCU has stored.
That makes total sense, a new cluster has zero miles on it so any miles you put on it will be "up".
Installing a used cluster with more miles and trying to turn them back and not being able to also makes sense because it is illegal to roll back a odometer and how easy would it be to roll back your OD and lie about the miles if there was not a default in the program for the OD?
Good info man, thank you.
Old Apr 3, 2013 | 07:31 AM
Roving Manatee's Avatar
4wd High
No check engine light. Pulled the instrument panel. It looks solid state. No access to the lights without disassembling the panel itself.
Old Apr 3, 2013 | 08:25 PM
And the back will come off of the panel with like a few clips and screws.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
gamecockdisco
Jul 12, 2010 08:34 AM
mydisco03
Oct 27, 2009 03:25 PM
rodrick smith
Apr 13, 2007 06:09 PM
Sean 1313
Aug 30, 2005 10:00 PM
