Traction Control Problems
This is bad information. It may be true with a NEW cluster (not sure... never considered using one) but it is certainly not how a used cluster works. If you put a cluster in with different miles than the BCU has stored, the cluster will still display the miles IT has recorded and will blink because it doesn't match what the BCU has stored.
Installing a used cluster with more miles and trying to turn them back and not being able to also makes sense because it is illegal to roll back a odometer and how easy would it be to roll back your OD and lie about the miles if there was not a default in the program for the OD?
Good info man, thank you.
gamecockdisco
Jul 12, 2010 08:34 AM
rodrick smith
Apr 13, 2007 06:09 PM
