Sponsored by: CARiD
tranny issues
Old Jul 10, 2005 | 01:44 AM
Bene's Avatar
Default tranny issues
when its cold (in the morning or when i get off work) my Disco wont shift from first for a while, sometimes reaching 5000 rpms before i let off for a bit. it seems to be getting worse and so far my only soloution is to let it warm up, thus making high revs safe, before i go anywhere, and therefore not really fixing anything.
thanks in advance.
Old Jul 10, 2005 | 11:20 AM
bluerover2002's Avatar
Default RE: tranny issues
i have the exact same problem on my 95 disco. Any help here is greatly appreciated!!!
Old Jul 10, 2005 | 09:42 PM
duboff's Avatar
operating on the idea that the fluid is there and at the correct level, and everything works after everything warms up. (at least shifts) The things i look for are. tranny filter, the fluid itself, the shift linkage in the transmission. the transmission pump. First guess would be filter. also check the 4 low range and see if that makes a difference. I know some vehicles with the low lock engaged it stays in 1st, check that linkage as well. I have not had the problem so i am just doing the troubleshooting thing, based on experienced with other vehicles. When you find out let me know. Maybe there is a way to prevent it. Hope it helps. duboff
rover1334
Jan 14, 2014 07:05 AM
DiscoByrd
Apr 7, 2013 08:40 PM
tornado_735
Mar 17, 2009 12:59 PM
MoNtErover
Sep 24, 2008 08:08 AM
Bene
Oct 26, 2005 11:17 PM
