Sponsored by: CARiD
Transfer box differential won't shift
Old Feb 1, 2009 | 06:11 PM
discogirl97's Avatar
Default Transfer box differential won't shift
I have never needed to use my transfer gearbox (I assume that's what it is called per my manual) and am now trying it out. I can't get it to shift. I have had the Disco for 3 years. It is a 97Disco 1. Can you tell me how to do it? There were several ways in the manual, one talking about putting the car in neutral and depressing the foot brake and the ER brake. My ER brake cable is broken. Could that be the problem?
If someone can walk me through the correct process, I will give it a try!
thanks so much!
Old Feb 2, 2009 | 10:03 AM
antichrist's Avatar
Default RE: Transfer box differential won't shift
Thank you for including the year and vehicle. It is amazing how many people don not.
If you cannot get it to work with one of the two ways under "Normal Method: Automatic Models" (assuming you have an automatic) as outlined in the manual then the "advanced method" is unlikely to to work either. Setting the parking brake is included just for Land Rover's liability, in case someone is too dumb to hold their foot on the brake.
Since you have no idea how long since it has been engaged, and it's been at least 3 years, the linkage is probably corroded enough to make it not easy to move.
You could try going to a self wash car wash and spraying underneath at the linkage. If that does not work you probably have some work to do.
importdave
Sep 25, 2014 10:18 PM
far4cges
Aug 6, 2012 08:25 PM
RobScan54
Aug 13, 2009 05:01 AM
sdsilvere38
Sep 18, 2008 05:25 PM
ant996
Defender
Sep 14, 2006 05:03 AM
