Sponsored by: CARiD
Transfer case oil
Old Jul 13, 2016 | 01:14 PM
hemicharger69's Avatar
85W140 was recommended on this forum:
https://landroverforums.com/forum/di...ffs-oil-43062/
Old Jul 14, 2016 | 05:15 AM
number9's Avatar
Originally Posted by hemicharger69
What was filled in #12? Is it separate internal compartment from #11?
Transfer case and just over filled same compartment. If you look at attachment appears the temp switch fitting is good bit higher than fill.
Originally Posted by Bom2oo2
Don't need to drain oil & refill,,
Just park at level ground and open #11, the real fill plug,!! Hahaha, and extra oil will pour out, then put plug back in place & you are good to go,
Agree. If you don't get any oil out punt.
File Type: pdf
Old Jul 18, 2016 | 02:52 PM
I drained approximately 2 quarts of the 1 gallon from the transfer case. The fill plug was just too difficult to access. There was this thick wiring loom in the way. The plug had a larger outer tightening nut that I couldn't loosen. I didn't want to risk breaking it off or rounding off the edges.
Most any other make, I wouldn't worry with % quart overfill. But, since we are talking about a Land Rover Disco, I am lying awake at night.
Old Jul 18, 2016 | 03:05 PM
WaltNYC's Avatar
Hemi, there is absolutely no way to know how much oil you have in there unless you remove the fill plug.
Anything else and you are just guessing. If that works for you, fine.
Old Jul 18, 2016 | 03:13 PM
mollusc's Avatar
I know that mine didn't have an outer nut, but I know what you mean about that wiring. A wobble extension allowed me enough flexibility to get past it.
Phototone
Apr 7, 2008 03:59 PM
sailorcolin
Feb 21, 2008 05:08 PM
alex of minnesota
Dec 8, 2006 09:52 PM
Td5
Sep 1, 2006 05:01 PM
disco12
Mar 6, 2006 05:02 AM
