transmission fluid
If it is anything like my 99 Range Rover 4.6 HSE, it is doable but a litle tricky.
This is what I did:
1 Place wheel chocks on wheels and engage E-brake
2 Jack up front end and place on jack stands.
3 Remove drain plug from bottom of Trans pan and drain into approp. container
4 Clear sludge off of plug, replace washer, and re-install.
5 Remove 6 10mm trans pan bolts & pan gasket, cleaning the magnet (if present) that is located at the bottom of the pan.
6 You might have toback out the center bolt on cross member.
7 Remove bolt holding suck tube with a Torx bit (mine was a T27)
8 Remove other 2 screws holding filter
9 Replace filter
10 Replace gasket, insuring and even fit all the way around. This can be a little tricky.
11 Replace 6 10mm screws.
12 Remove the fill plug at the top of the pan. Mine was located at the top right.
13 I had to rig a long plastic tube to the end of a trans funnel and bungie-cord it to the front grill.
14 I ran the tube over the tire down through the frame and to the trans fill hole. I also had to bungie-cord this so the tube would stay inside the fill hole. Keep the drain pan in place.
15 Add trans fluid (Dextron III) until it overflows a little.
16 Start the truck, shifting through the gears.
17 Add more fluid until it overflows again.
18 I repeated this several times until it overflowed quite a bit.
19 Quickly reinsert the fill plug and torque it appropriately.
20 Remove stands and you are done!
This is what I did:
9 Replace filter
LRScott
03-04-2009 08:39 AM
