Sponsored by: CARiD
transmission fluid
Old Jun 12, 2007 | 04:26 PM
slotguy2's Avatar
Default transmission fluid
Were do you add Tranmission Fluid to a 2000 Discovery I cant find it or does the Dealer have to do it?
Old Jun 12, 2007 | 05:48 PM
Default RE: transmission fluid
How many miles on your truck, when was it last serviced, is your tranny leaking?
To drain or fill it, you have to access the drain or fill plugs on the tranny pan, dealer doen't have to do it.
Mike
Old Jun 18, 2007 | 10:52 PM
dalfier's Avatar
If it is anything like my 99 Range Rover 4.6 HSE, it is doable but a litle tricky.
This is what I did:
1 Place wheel chocks on wheels and engage E-brake
2 Jack up front end and place on jack stands.
3 Remove drain plug from bottom of Trans pan and drain into approp. container
4 Clear sludge off of plug, replace washer, and re-install.
5 Remove 6 10mm trans pan bolts & pan gasket, cleaning the magnet (if present) that is located at the bottom of the pan.
6 You might have toback out the center bolt on cross member.
7 Remove bolt holding suck tube with a Torx bit (mine was a T27)
8 Remove other 2 screws holding filter
9 Replace filter
10 Replace gasket, insuring and even fit all the way around. This can be a little tricky.
11 Replace 6 10mm screws.
12 Remove the fill plug at the top of the pan. Mine was located at the top right.
13 I had to rig a long plastic tube to the end of a trans funnel and bungie-cord it to the front grill.
14 I ran the tube over the tire down through the frame and to the trans fill hole. I also had to bungie-cord this so the tube would stay inside the fill hole. Keep the drain pan in place.
15 Add trans fluid (Dextron III) until it overflows a little.
16 Start the truck, shifting through the gears.
17 Add more fluid until it overflows again.
18 I repeated this several times until it overflowed quite a bit.
19 Quickly reinsert the fill plug and torque it appropriately.
20 Remove stands and you are done!
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
ferrelltodd
Aug 9, 2005 10:11 PM
