Sponsored by: CARiD
Transmission Trouble 2003 D2
Old Jan 7, 2018 | 11:44 AM
berlindisco2's Avatar
Default Transmission Trouble 2003 D2
My 2003 Discovery 2 SE7 has a button that sits right behind the shifter. It does nothing because my car didn’t have that option, but I believe it changes modes like into sport. However, when it is cold outside, my transmission doesn’t work and it must be because of this button. I’ll start the car, and a blinking light comes on, it is like a gear with an M in the middle. That starts blinking, then the D for drive starts blinking both on the dash and in the shifter. I’ll put the car in drive and it will only start off in second gear, and stay there. Once the car warms up, I’ll turn it off and on again and the transmission is normal. What the hell is happening? Furthermore, how do I add transmission fluid? I think I have a leak and I know there isn’t a full tube in the engine compartment so it is located on the transmission itself? Thanks for the help!
Old Jan 7, 2018 | 03:42 PM
number9's Avatar
Prior to making any suggestions......
How long have you had this problem? Did you notice this yesterday, last week, weeks, month or last year when cold too? Does it happen often?
What are your recent local temps and are you affected by the cold snap?
Thanks.
Old Jan 8, 2018 | 05:58 AM
Default History
well last year my disco died in a parking lot and I had to jump it. After jumping it, I drive a little bit before realizing that my transmission was stuck in second gear. It did it a little bit during the winter, but it was easily fixed by turning it off and on a few times. Then in the spring my car died again, I jumped it, and the same thing happened. I finally had enough money for a new battery so when I replaced it the transmission stopped acting up. This winter it has been much more aggressive with this problem. It started in the early fall, and has continued to do it in the winter. Could it be some kind of fuse that was damaged by jumping it?
Old Jan 8, 2018 | 08:04 AM
number9's Avatar
Mechanical limp home
The gearbox is fixed in 4th
gear if the fault occurs while the vehicle is moving, or 3rd gear if the fault occurs while the vehicle is stationary.
When your D2 was new it had and probably still has the "option" of Normal, Sport when button pressed in high transfer case range and Manual if pressed in low range. You're likely mistaken when saying 2nd gear and it sounds like it's in limp mode due to the flashing M. Normally you should be seeing the S (Sport) blinking along with M when in limp mode. Believe your magic bus D2 has a S warning light issue also.
Thanks that's some useful information. First things I'd check or have someone check are to make sure your new battery is fully charged and the fluid level in the transmission. There is no dip stick tube to check or add trans fluid on the D2, it done via the fill plug. Some tools, time and effort is required to check level and/or add fluid. You can use the info in this link or print out for reference. https://landroverforums.com/forum/ge...roblems-87650/
Determine the battery is OK and the trans fluid is serviced properly. If you still get a flashing M with the limp mode let us know because you may need to consider a X,Y,Z switch replacement.
kducat
Jul 8, 2017 11:36 PM
Matt_Attack352
Jan 13, 2014 09:55 AM
hateroffreelander
Aug 23, 2009 11:34 AM
gregnatex
Jul 15, 2006 11:03 PM
DJXNRG
Dec 4, 2005 11:57 PM
