Sponsored by: CARiD
Tricky question?
Old Jun 15, 2010 | 06:22 PM
justbecause82287's Avatar
3rd Gear
Question Tricky question?
I have a 99 Land Rover Disco radio keeps resetting? It does not keep my stations( not factory radio) I have to keep setting them over and over. Then just recently it wont go to start. acts like it is completely dead? I don't know where to start with this? Just a few weeks ago S & M lights were flashing and went into limp home mode but got the air filter changed also had an issue with when A/C was on it would have an issue with leaking onto motor. Perhaps why S & M lights were on? have not had issue with lights again and just have not used air at all.
Old Jun 15, 2010 | 06:35 PM
yloDiscoII's Avatar
I'm guessing you have a DII?
M & S flashing could be caused by your battery going bad...this could also be triggering your radio issues. Anything lower than 13 Amps and your transmission electronics will take a hit. I would start there as it's the most simple fix....get a new battery.
If your battery is OK, then it might be your XYZ switch is going bad and you'll need to replace it.
You may want to worry about your transmission issue before you worry about your friggin presets.....
etsZac
Jan 12, 2014 08:57 PM
Robover01
Jun 16, 2011 11:59 PM
jycsalas
Dec 4, 2010 11:16 AM
javoli002
Oct 30, 2009 10:51 PM
javoli002
Defender
Aug 25, 2009 10:20 PM
