Trouble starting disco sometimes...
i ahve a 96 disco SD and sometimes when i tunr the key to start it nothing happens at all...not even anything electrical like the radio or the dash indicators.. i have a technique that sometiems works which is press down on the brake and the car starts up but sometimes the trick doesnt work.... im guessing its something electrical because sometimes if i just want to turn the key to jsut turn on the accesories they turn on but the radio and other electronics either flicker on and off or turn off completely unless i turned the key all the way to start it, im also guessing amybe theres a loose connection. yea ive been havign alot of electrical problems wiht my expierence owning a land rover but mechanically its awsome.. when i frist got it i had to fix the switches for the ower windows and i jsut recently replaced the turn signal and headlight switch.. so if anyone could cluse me in on wut maybe the problem id be very pleased. thx!
the 96 has 4 main body grounds. the location are on the british atlantic site in tech tips. If you have a loose or dirty connection it will do all kinds of strange things. The two that give my the most trouble are the ones behind the kick panels. the battery, connections, and last but not least. the ignition switch. hope it helps. gotta love a rover. duboff
lead.sled.fan
07-22-2010 08:01 AM
