Sponsored by: CARiD
Trouble with starting the engine
Old May 24, 2010 | 05:45 PM
roccomarconi's Avatar
Default Trouble with starting the engine
I have a 94 disco, and sometimes when i to turn the key, nothing happens. I finally found a way to start it when it doesn't turn over. I sit in the passenger side and push in on the floor panel next to the door and turn the key at the same time. For whatever reason it starts right up. I took the panel off but don't know if it is a wire corrosion or if it is a relay switch. Does anyone have any insight to this problem? Cheers
Matt_Attack352
Jan 13, 2014 09:55 AM
socrazy2992
Jul 14, 2012 05:12 AM
63gstone
Aug 30, 2010 07:34 PM
sdsilvere38
Feb 3, 2009 05:35 PM
smt
Mar 1, 2008 11:44 PM
