Sponsored by: CARiD
Ultra Gauge ammeter?
Old Oct 5, 2012 | 09:58 AM
Michael M. Koch's Avatar
Default Ultra Gauge ammeter?
Perhaps I'm missing something, but does the Ultra Gauge display the current draw on the alternator/battery? All I could find was an odd voltage gauge. Odd as in it had "bank 1 something voltage, bank something 2 voltage, etc." I have no idea what this means.
Old Oct 5, 2012 | 11:39 AM
Those small voltages would be the O2 sensors. There should be a supply voltage for the OBDII port that the unit can see, some others have posted about that, would be above 12 volts. Like 13.6 - 14.4, etc. As for amps, nope. I used a commercial clamp on DC amp meter, and my D1 stock alternator has to deliver about 85 amps at idle with everything on, wipers, AC, heater fan, lights, radio (basic after market, not a blaster model designed to crack the windows of Jeeps at 200 meters). A D2 will draw a little more. The stock starter draws almost 300 amps when cranking the truck.
Old Oct 5, 2012 | 12:41 PM
Thank you sir!
Old Oct 5, 2012 | 09:11 PM
Yes you can, look for the UG VOLTS reading, that will tell you the volts to the OBD port, which should be what the truck is putting out.
Rover_Hokie
Feb 2, 2014 03:52 PM
Discolife
Nov 23, 2011 07:58 PM
01d2Jeff
Nov 19, 2011 10:52 AM
Spike555
ROAMING WITH FRIENDS
41
Oct 24, 2011 06:26 PM
G Reeves
Oct 23, 2011 07:39 PM
