Sponsored by: CARiD
Urgent! M&S after driving off road
Old Jul 22, 2017 | 09:46 PM
twhit2016's Avatar
Default Urgent! M&S after driving off road
ok....I literally just got my 2001 Disco 2 running, test drive an blew a tire which threw me off the road. I went down about 10-15 ft into a ditch off of a field. M&S light flashing and it wont start or allow me to switch gears from Park. Any ideas? Wife came and got me, I am charging the battery as we speak. Any help appreciated.
Old Jul 22, 2017 | 10:13 PM
No Doubt's Avatar
The 4 most-talked about causes of M+S limp home mode are:
#1: low battery voltage
#2: bad xyz Neutral Safety switch
#3: bad transmission ecu
#4: oil on crank position sensor (CPS) or loose CPS connection
Also, you can force the gear selector into your desired gear by gently lifting your black shifter gear-display bezel and pressing the gear lockout pin on the back of the shifter lever underneath.
Old Jul 22, 2017 | 11:35 PM
twhit2016's Avatar
thank you for the help. Blew a fuse lol. Man these rigs are unbelievable. So it was more a levee than a ditch here is a picture. Yes that is me and the 01 disco 2 waaaaay down there. Replaced a fuse drove to a road changed a flat and drove it home.
Old Jul 22, 2017 | 11:37 PM
No Doubt's Avatar
Cool pic! Tough truck. So, what blown fuse caused the M+S?
Old Jul 22, 2017 | 11:48 PM
twhit2016's Avatar
blew F13 and F5...F13 wouldnt allow me to start F5 just made it run HOT
Old Jul 23, 2017 | 12:06 AM
No Doubt's Avatar
BCU and the cooling fans?!
So maybe the alarm BCU can trigger the M+S limp home mode??
Old Jul 23, 2017 | 12:19 AM
twhit2016's Avatar
Don't get me lying.
it is amazing though tough as nails but I find it amazing all of the goofy issues I had getting it to run. Inertia switch, fuses, then battery terminals. An hour after getting it to run I am going on a roller coaster ride. Changed the flat and drove it home. Amazing! I literally had it for sale but took it down as soon as I drove it home.
AZRover
Aug 15, 2016 05:52 PM
ge234
Jul 25, 2014 08:34 AM
TATZOO
Sep 10, 2012 04:10 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Torancis_LR
Jul 10, 2009 11:27 PM
