Sponsored by: CARiD
Usual key remote lock control damage,......contacts missing, anyone fixed this?
Old Jun 11, 2013 | 06:25 PM
bcolins's Avatar
Default Usual key remote lock control damage,......contacts missing, anyone fixed this?
This is my Second Disco 2 with this problem. The usual plastic key head damage (buttons are blown out)
I ordered a couple new keys and the remote insert will not lock or unlock the doors when I insert it into the new key blank.
It WILL lock and unlock the doors if I bridge the tiny brass contact points in either the lock or unlock switch points with something like the tip of a small flat tip screwdriver................Look at my picture; the lock and unlock switch points are the small vertical black plastic rectangles with the round contact point near the top,....and a narrow horizontal contact point near the bottom.
I'm thinking that there must be a small spring-returned contact strip that the plastic buttons press on to bridge the two contact points.
I've attached a pic.
Any thoughts on how this can be fixed short of buying a new remote module?
Brian
Attached Thumbnails Usual key remote lock control damage,......contacts missing,   anyone fixed this?-2003-disco-2-key-remote.jpg
Old Jun 12, 2013 | 07:09 AM
drowssap's Avatar
if you search thru ebay there is someone selling a new case w/ the new button you would have to soldier them in place
Old Jun 20, 2013 | 08:32 AM
bcolins's Avatar
I already have those,.....they don't work, as they don't include the metal contact to bridge the two copper contact points on the remote module. Identical issue on my last Disco.
Again, I can activate the remote module and lock/unlock the doors, if I bridge the copper contact points on the circuit board with a tiny screwdriver tip.
Anyone found a fix for this?
Old Jun 29, 2013 | 05:22 PM
bcolins's Avatar
Surely someone else has had this problem, and fixed it.
Old Mar 8, 2015 | 12:16 PM
bcolins's Avatar
Drowssap: I eventually figured out that you were actually referring to what I bought,....replacement micro switches that need to be soldered on to the circuit board. Your "soldier" threw me for a loop. Didn't know what you meant,....doh!
Finally got around to ordering the replacement key with 4 replacement contact buttons. I didn't want to attempt soldering something this small on a circuit board. Stopped in to a local "Batteries +" last week to see if they wanted to attempt it since they solder batteries packs every day. They couldn't guarantee it would work,.....but I was confident. It took them about 15-20 minutes of fiddling with it,....one of the solder joints was not flowing properly. They finally got it to a point where it was functional, albeit,......a bit ugly. They didn't charge me anything to do it,.....said they didn't want me coming back being if it failed after a bit......lets hope it holds together. Now just gotta repair or replace my driver's door lock actuator.
Old Jul 19, 2018 | 04:59 PM
Dealer can cut by vin I believe
Old Jul 19, 2018 | 08:17 PM
bcolins's Avatar
I would expect Army Rover to be right on that. Most if not all European manufacturers do this,...some will require proof of ownership such as seeing the title.
Old Jul 19, 2018 | 08:20 PM
bcolins's Avatar
Originally Posted by National1tyres
No key. LOST CAR OPEN
HELP WHAT'S THE BEST OPTION
SECOND HAND BARELL AND KEY HELP PLEASE
Probably should have started a new thread since this is an unrelated and old thread,...heck I sold that Disco a year ago I think.
Old Jul 19, 2018 | 08:58 PM
this was one of the newer threads he revived....
DiscoIIEvan
Oct 18, 2012 04:19 PM
bribake
Jun 20, 2012 02:39 PM
Rover_Hokie
May 21, 2012 03:53 PM
00&04 Disco
Oct 20, 2010 04:14 PM
russcan
Sep 14, 2008 10:45 AM
