Sponsored by: CARiD
Vacuum Hoses
Old Jan 11, 2006 | 01:03 PM
hzuni's Avatar
4th Gear
Default Vacuum Hoses
I have recently purchased a 95 Disco and noticed a rough idle (not too bad, but you can notice it). I new to Land Rovers so my question is, the vacuum advance has 2 ports, 1 of thje ports has a hose going to the top of the air intake. Where if any does the second go to??? there is no hose attached.
Would appreciate a diagram or just send a little help.
Old Jan 12, 2006 | 01:54 AM
MadBilly's Avatar
Default RE: Vacuum Hoses
good question i have same problem, it doesnt affect it running, it just idles rough. sometimes it doesnt, it depends on mines temp.
Old Jan 20, 2006 | 02:30 PM
Landzu's Avatar
I would try a vacuum cap and see if it help.
Old Jan 24, 2006 | 11:34 PM
Bait's Avatar
Welcome Hzuni !
The second port is not used. The first port is used to advance the timing on your 14 CUX Lucas fuel injection system. Remove the distributor cap and see if the rotor can be moved back and forth. It's common for the distributor shaft to seize and advance the timing causing a rough idle. There are many other possibilities of a rough idle.
Lukas88
Aug 11, 2011 05:36 AM
shearer60
Sep 23, 2007 08:40 AM
huckleberry
Mar 29, 2007 04:20 PM
98TDIAUS
Nov 26, 2006 11:13 AM
hzuni
Jan 10, 2006 12:31 PM
