Sponsored by: CARiD
vibration
Old Jan 1, 2008 | 12:01 PM
mwyrick45's Avatar
Default vibration
has anyone experienced a vibration in the disco2 at speeds of like 70+?
Old Jan 1, 2008 | 03:39 PM
Default RE: vibration
Sure. So what have you checked so far, what condition are your tires in, how often do you grease your u-joints, have you rebuilt your front drive shaft yet installing new servicable u-joint in the double cardon?
Old Jan 2, 2008 | 11:36 AM
mwyrick45's Avatar
I talked to land rover and he said that installing new ujoints only can cause the driveshaft to go out of balance... true???
Old Jan 2, 2008 | 06:17 PM
No, that is a typical Dealer response. So back to my first question, what have you checked so far, give us some help.
Old Jan 2, 2008 | 10:10 PM
DiscoOn22s's Avatar
mike what are u joints ? and why do i need to grease them?
Old Jan 3, 2008 | 09:39 AM
Your drive shaft has u-joints on it to allow it to flex and rotate to make your truck go. If they are not greased every year or 12,000 miles they will break with grease and you can pay upwards of $7000 in repairs.
That being said, and since you own a 4wheeler, I would really suggest you do everything you can to learn about what makes your truck work, it is much cheaper in the long run.
Old Jan 3, 2008 | 03:00 PM
DiscoOn22s's Avatar
Thanks mike! And thats why I'm here asking you questions everyday so I can learn. However I do also do my own research so I dont have to flood you with questions.
Kiwi Mike
Mar 2, 2006 07:32 AM
kennims
Jan 22, 2005 08:22 AM
Greyfoxvt
Jan 9, 2005 09:04 AM
berg7171
Dec 27, 2004 06:35 PM
Benhamtroll
Dec 13, 2004 04:35 PM
