Sponsored by: CARiD
Vibration When Accelerating
Old Nov 13, 2006 | 08:57 PM
aladisco's Avatar
4th Gear
Default Vibration When Accelerating
2000 Disco II , about 75,000 miles. Experiencing a lot of vibration when accelerating. Initially thought it might have thrown a wheel weight...tire guys said it was probably transmission. Transmission guy hooked it up, did some diagnostics, said it was either engine performance problem or harmonic balancer - as you probably know, its a sealed case so he is hesitant to open it until some other things are eliminated.
The vibrations occur under power / load and stop when coasting and almost have a "grinding" feeling when it occurs.
Any thoughts?
Old Nov 13, 2006 | 09:21 PM
geoman's Avatar
Default RE: Vibration When Accelerating
Check your rear driveshaft flex coupling. It is a rubber/metal doughnut shaped part that bolts between the shaft and the rear differential pinion flange. These develop cracks in the rubber over time, and when about to fail ---introduce a lot of vibration into the vehicle, especially at highway speeds. I have them in stock for $78.00---if that turns out to be your problem.
regards,
Geoman
www.eurotekapg.com
Old Nov 13, 2006 | 11:24 PM
NYDISCO's Avatar
Just had to replace my front drive shaft assembly due to that same problem in my 2001 DII. The front driveshaft unlike the rear does not have grease fittings... I took mine out and had it rebuilt for under 200 bux(if you get it rebuilt have them put fittings on it..).. The dealer wanted to replace the whole thing for about 1000.00!!! (Can you feel the vibration in the steering wheel???...If you can it is a good sign it is the front DS..)
Old Nov 14, 2006 | 10:04 AM
ORIGINAL: NYDISCO
I also am having to do the same rebuild, the double cardon, or constant velocity joint, will fail from not be sericed and you need to change out the u-joints ASAP. If it fails, it can also break the tranny case causing you you to spend the BIG $$$$'s.
As already mentioned, you can get the shaft rebuilt for under $200.
Mike
novavon
Aug 11, 2011 09:59 PM
droland@teksinc.com
Jun 18, 2011 02:50 PM
Jupe209
Sep 1, 2010 05:06 PM
97DISCOIDAHO
Apr 16, 2007 01:32 AM
film guy
Dec 20, 2006 11:22 AM
