Sponsored by: CARiD
Warning lights
Old Jul 17, 2007 | 02:36 PM
madmax's Avatar
5th Gear
Default Warning lights
I have 3 warning lights lit on the dash, they all came on together, the 3 lights are the TC, ABS & Suspension level lights. Switch off and they go off and stay off for around a week or so, but they do appear again is there anything I can check to eliminate components. Thank you all in advance.
Old Jul 17, 2007 | 03:11 PM
Default RE: Warning lights
There are probably 200 posts on this site along for the trio of lights.
If you have a favorite shop go see them, have them scan for fault codes then clear them, see if they come back.
Mike
Old Jul 18, 2007 | 04:10 PM
madmax's Avatar
5th Gear
Thanks again mike, I'll give it a go.
Regards, Martyn
Old Jul 19, 2007 | 04:09 PM
MBirtch's Avatar
5th Gear
madmax, please let me know what you find. I was told I needed a new shuttle valve and that there is now a replacement kit $800 + $400 labor.
Hopefully you find another solution.
Good Luck!
mb
Old Aug 22, 2007 | 02:44 PM
LrTECH's Avatar
no point in replacing the shuttle valve switches as they dont fix anything. They will keep thelights for a little longer. You have to replace the entire modulator to remedy the issue all together.
cipher982
Nov 9, 2019 11:22 AM
gmutis
Jul 21, 2006 04:43 PM
ptmelendez
May 12, 2006 08:06 PM
ChrisK
Freelander
Dec 19, 2005 01:38 AM
skilley
Dec 12, 2005 09:24 PM
