what oil to use
what oil to use
hi, ive just brought a land rover freelander serengeti 5 door 1.8i
can someone tell me what oil to use for it please as i have no idea which one to put in and i have to go for a long drive later this week.
can i mix the oils, ie put in new oil with the oil inside, not knowing what the previous owner had put in.
i have to wait until i get to london until i can take it to my mecanics and get a full oil change.....
help...
help...
from the shop manuals (part of the free RAVE download) -
You can mix oil, for short term use. It would be best to have an oil change and have it all the same. But full of oil (mixed) is better than long trip low on oil. Also, since new to you, check oil several times on this trip to be sure you are not having a leak.
Engine oil – K1.8 engine
Use a 10W/40 oil meeting specification ACEA A2 or
A3.You can mix oil, for short term use. It would be best to have an oil change and have it all the same. But full of oil (mixed) is better than long trip low on oil. Also, since new to you, check oil several times on this trip to be sure you are not having a leak.
Excuse me Sir, but you need to try again on the download, all I have is real PC, not Apple scrap, and ordinary garden variety IE.
If you can't read the post I sent with an exact copy of the info clipped from the owner's manual, the you may not have much luck if you do download the whole manual.
If you don't understand what 10W40 is, you have no business changing oil yourself.
If you can't get your hands dirty, you don't need to own a Land Rover, or be under one.
If you proceed to the dealership they are waiting for you.
If you want to do the work yourself, look at these attached pages from the shop manual. You'll need tools of course, some ramps to pull the front wheels up on, and you must remove an under body panel to get at the drain. Plan on having 4 quarts of quality oil on hand to refill.
Or go the dealer route - see photo.
Apple is way better than PC any day of the week.
Not everyone wants to work on their own car, nor cares to and that is fine.
He asked a simple question, thus a simple answer is all that is needed, depending on his climate 10w-40 or 5w-40 are both good all around motor oils.
Yes you can mix oils, they are all compatible, yes it is best to pick one oil and stick with it, however, if you need to add oil then just buy oil and add.
thanks spike, this is the kinda response i need.
if i was a car mecanic, super nerd, i wouldnt need to be on here asking such simple questions.
i just neeed advice and thats the kindest yet.
i have a very busy life and unfortunatly cant be using ramps, buying tools, wasting a couple of hours under my car.....i dont have the time. babies, kids, wife, job, houses, dog, mum in law, etc etc...see my point
thanks buzz for your help, but no need to get all darth vadar on me lol
ill try to downlaod again. and in the mean time just put some oil in till i get to london to see my mecanic xx
ps whats the yellow button for on the gearstick?
