Sponsored by: CARiD
Wheel Bearing Noise
Old Dec 26, 2012 | 08:45 PM
mudbug308's Avatar
Default Wheel Bearing Noise
Does anyone know of an easy way to pinpoint a bad wheel bearing? im thinking about lifting all four wheels off the ground set truck on jack stands and use a listening scope on each hub. I'm just not sure if it will work since there wont be much of a load on the bearing this way.
Old Dec 26, 2012 | 08:46 PM
mudbug308's Avatar
by the way i am working on my 02 Disco
Old Dec 26, 2012 | 09:25 PM
Drive around 30-40mph in a straight line, then turn left, does the noise go away?
If yes then its on the right side.
Same thing turn right, does it go away?
If yes then its on the left side.
If its bad enough to make noise you can hear going down the road you will be able to wiggle the wheel with it off the ground, 9 and 3, wiggle back and forth.
Old Dec 27, 2012 | 12:41 PM
Rovin4life's Avatar
check the front end for looseness. if it moves up and down and all around then its the wheelbearing.
Grlica
May 1, 2013 06:13 PM
Harvard
Jun 18, 2009 07:32 PM
Aquaholic
Jun 15, 2007 10:30 AM
btp226
Jun 21, 2006 05:35 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
