Sponsored by: CARiD
Windshield leaks. No cracks. Can I replace weatherstripping? 98 disco
Old Jan 11, 2017 | 09:03 AM
Marls98disco's Avatar
6th Gear
Default Windshield leaks. No cracks. Can I replace weatherstripping? 98 disco
I have a 98 disco. Water leaks from the top and is getting my headliner wet. Is there weatherstripping out there to replace or is this a job for a glass company and glue?
Old Jan 11, 2017 | 09:20 AM
WaltNYC's Avatar
Are you sure it is the windshield? Often the sunroof is the culprit.
Old Jan 11, 2017 | 10:25 AM
6th Gear
Actually no I am not sure if is the windshield rubber. The drip starts somewhere behind the headliner and appears at the top of the windshield.
Most of the headliner is dry, just the area of the leak is damp. Also I only notice after rain and not a car wash.
Anybody know how involved removing the headliner is?
Old Jan 11, 2017 | 06:20 PM
yellow02's Avatar
I also have a 98 D1 with the same issue. I thought for the longest time it was the front wind screen and had the rubber changed twice when the wind screen was replaced. It turned out to be the drain from the sunroof was the issue.
Old Jan 11, 2017 | 10:07 PM
6th Gear
Default Leak
That sounds like another potential cause. I may hit the window with the garden hose, keeping the water far from the sunroof and see if I can isolate the problem.
where is the drain located? Did you have to remove the headliner?
My leak is located just to the right of the rear view mirror.
Old Jan 12, 2017 | 07:07 AM
WaltNYC's Avatar
Jump over to the D1 section of this forum. In the 'sticky' thread near the top of the list you'll find a bonanza of info about how to do most everything on/to your truck.
https://landroverforums.com/forum/di...ep-step-33276/
P.S. although you mentioned what model year you have, it is always best to put that info in your signature so everyone is clear. Look for the 'User CP' just above the 'new reply' button at the top of this thread.
Spencerfitch
Sep 27, 2020 12:17 PM
uoflcardfan77
Aug 6, 2015 03:47 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
Camdisco24
Dec 3, 2008 06:31 AM
ek5usmc
Oct 10, 2008 10:32 PM
