Sponsored by: CARiD
wobble in steering when on wide curve/ bought tires recently also bearing fix
Old Oct 13, 2015 | 07:30 PM
klandrover's Avatar
Default wobble in steering when on wide curve/ bought tires recently also bearing fix
Since buying tires and having the right bearing replaced I have gotten occasional wobble or shimmy in the steering wheel. Can be intense. It happens when road is veering to the right and long turns. It does not happen often not even in the example above and does not happen when I am turning right. I know it has also happened when I have hit several bumps in succession. I thought it was a bad tire because I did have this thing happen a long time ago and when changed tire it was gone. Took it to shop just looked at tire and said it does not have as obvious bulge but I should have tested. I took it to Mr. P a quick tire changing place and he said he thought is was that the tires that I have Cooper Discoverer a t / 3 are too aggressive for my truck and he personally would not have sold them to me. Could bearing be bad? Tire? The shop that put on tires and fixed bearing was a nightmare to deal with. Thanks for any ideas/ help.
Old Oct 13, 2015 | 07:41 PM
fishEH's Avatar
Search here for "death wobble" and you'll find everything you meed. Could be swivel preload, TRE's, bushings, or a combination of the three.
Old Oct 14, 2015 | 07:26 AM
drowssap's Avatar
x2 there is a whole list of thing that can cause your death wobble, you just have to cross them off your list as you go.
Old Oct 15, 2015 | 02:22 PM
uoflcardfan77's Avatar
I would get the "death wobble" every once in a while when braking. Mine ended up being the lower control arms and tie rod ends.
yukonridin23
Sep 22, 2009 01:18 AM
alexarker
Dec 23, 2008 01:51 PM
jimrrsport08
Jul 23, 2008 07:22 PM
Justmealex
Oct 19, 2006 06:45 PM
