Sponsored by: CARiD
wont go into reverse
Old Jun 29, 2013 | 06:16 PM
eleuthera's Avatar
3rd Gear
Default wont go into reverse
Hi there..I am a new member and also a new owner of a 2002 LR Disco 2. My vehicle is on a small island in the Bahamas that causes some obvious problems...anyway...on my last visit the vehicle would not switch into reverse from time to time...there are no transmission issues...it seems electrical...I was curious to know if this could be related to a switch for the brakes and the cruise control...when I think back to when the problem occurred i was playing with the cruise control ...any suggestions would be great...
Old Jun 29, 2013 | 09:19 PM
There is a switch on the side of the transmission that reports to the transmission computer what position you have moved the selector to. It is called an XYZ switch. It can get full of mud or sludge from "wading" or just the AC condensate drain dumping on it. It can be removed, split apart, cleaned out, and re-sealed.
Old Jun 30, 2013 | 09:03 AM
Also, is your service engine light on, if so get the fault code numbers and post them which will help us help you.
Old Jun 30, 2013 | 12:07 PM
eleuthera's Avatar
3rd Gear
thanks for the posts...I have taken this "hobby" on an island that does not have a lot of service options...not sure why...lol...but i see there is a lot of help here...so..i will keep going with it...is there a tool that can be purchased to get the codes?...
Old Jul 1, 2013 | 07:15 AM
Northtosouthkaz's Avatar
I had this trouble and after taking apart the shifting cover, there was a sheetrock screw (not mine) that lodged and prevented movement, Im guessing all kinds of stuff from previous owners could do this.
PITTDISCO
Feb 1, 2013 07:02 AM
CUpgt
Jul 1, 2011 12:30 AM
Prowler9876
Feb 8, 2010 05:53 PM
96p384.6
Sep 14, 2006 01:48 PM
