Sponsored by: CARiD
Yes, another question on O2
Old Sep 23, 2016 | 12:02 PM
VWnut's Avatar
Default Yes, another question on O2
Changed all 4 O2 sensors, still getting the following codes.
P0141 O2 sensor heater circuit malfunction (bank 1,sensor 2)
Rear sensor heater LH bank - short/open circuit (NAS
and EU-3 only)
P0161 O2 sensor heater circuit malfunction (bank 2,sensor 2)
Rear sensor heater RH bank - short/open circuit (NAS
and EU-3 only)
P0134 O2 sensor circuit no activity detected (bank 1,sensor 1)
Front sensor LH bank open circuit
P0154 O2 sensor circuit no activity detected (bank 2,sensor 1)
Front sensor RH bank open circuit
I checked the fuse- no go.
Next I am going to check the following and correct as needed.
1. Power to the O2's
2. Ground
3. continuity from the sensor to the ecm
My question is "Has anyone had these 4 at the same time, if so what was the solution?" Second, any steps I am missing? Thanks, S-
Old Sep 23, 2016 | 06:25 PM
ihscouts's Avatar
For one thing you want to note which vehicle your referring to like Disco Series II or Range Rover Classic, Range Rover P38, etc., etc..
Next I would either suspect the ECU, the wiring or fuses (if any) for those circuits. Are you sure you have the right O2's for your model?
Dan7
Nov 28, 2012 09:04 PM
tibetrover
Nov 21, 2012 01:44 PM
collin Barrows
Audio/Visual Electronics
Aug 21, 2011 12:47 PM
mdf27
Mar 22, 2011 06:01 PM
tskeltonPGA
Jan 16, 2008 07:21 PM
