03 LR2, installing oil pressure guage?
Old Sep 28, 2021 | 04:22 AM
cactus13's Avatar
7th Gear
Default 03 LR2, installing oil pressure guage?
Hello, can anyone suggest where I can route a 1/8" oil pressure line through the fire wall without having to pull the engine? Sorry for the sarcasm but I just can't locate any options and I'm considering drilling the firewall, preferrably on the passenger side to keep the line shorter. Could the line be brought in through the transfer gear lever opening in the center console?
Thank you for any ideas.
Cheers,
Dana
Old Sep 28, 2021 | 09:10 AM
flybd5's Avatar
You need to clarify what vehicle you have. There are no "03 LR2" models. The vehicle was produced from 2008 to 2015.
Old Sep 28, 2021 | 11:08 AM
cactus13's Avatar
7th Gear
Can't believe I did that... so lame and obviously so tired at 2:30am. I'm working on my son's 2003 Land Rover Discovery 2. Just finished valve cover gaskets, in-line thermostat mod, coils, ignition wires and #8 cylinder cross-threaded spark plug hole. Oil pressure gauge is mounted on bottom of ashtray. Drilled and tapped the oil cooler fitting above the oil filter.
Thank you for any help and ideas,
Dana
Old Sep 28, 2021 | 11:16 AM
flybd5's Avatar
Dana
​​​​​​Wrong forum...
Old Sep 28, 2021 | 12:50 PM
ThorInc's Avatar
Dana
Ask a Mod to move the thread. The Discovery folk won't likely see it here.
Old Sep 28, 2021 | 12:56 PM
flybd5's Avatar
Or just copy/paste. Should take all of 15 seconds.
zoltz
LR2
16
Jun 9, 2020 06:43 PM
bcolins
Oct 18, 2016 07:06 PM
EliFolsom
Mar 4, 2016 06:15 PM
LR2driver
LR2
Nov 6, 2013 08:21 PM
shonuff93
Sep 21, 2009 03:57 PM
